CÓMO
Crear informes de resumen con estilo infográfico
Last Published: September 5, 2023
Resumen
Starting at ArcGIS Pro version 2.7, the Summary Reports tool can create infographic-style summary reports. Infographics are newer-style reports, displaying information using compelling graphics and charts, while summary reports are more tabular-styled reports.
The infographic report templates are available for local data after installing the USA 2020 data patch.
Procedimiento
Download and install the USA 2020 data patch
  1. Log in with an ArcGIS account, and download the USA 2020 data patch.
  2. Unzip the USA 2020 data patch. The patch contains one folder and one XML file:
    • Datasets folder
    • dataset_description.xml
  3. Copy and paste the contents of the patch to your US 2020 data location:
    <install path>\ArcGIS\Business Analyst\US_2020
Data location
  1. Delete the Business Analyst cache located in your user profile:
    C:\Users\<user name>\AppData\Local\ESRI\Business Analyst
Create an Infographic Report
  1. Open ArcGIS Pro and set the data source to USA_ESRI_2020.
  2. Open the Summary Report geoprocessing tool.
  3. Select one of the the Standard Infographics report templates.
    These are now available, in addition to standard Esri Reports
Create Reports dialog with new templates
Id. de artículo: 000025234
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
