HOW TO
Select features that are not within or intersecting the features of another layer in ArcGIS Pro
Last Published: July 1, 2021
Summary
Selecting features using the Select By Location tool is basic, useful data analysis. By default, the Select By Location tool provides a list of spatial relationships, such as Intersect, Contains, and Within, that select features which intersect or are within another layer's features.
It is also possible to select features that are not within or intersecting features of another layer by checking the ‘Invert spatial relationship’ check box when configuring the Select By Location tool. Clicking the Switch button in the attribute table after selecting features using the Select By Location tool will yield the same results.
This article provides instructions to select features that do not intersect or are not within the features of another layer in ArcGIS Pro.
Procedure
Use one of the following options to select features that are not within or intersecting features of another layer in ArcGIS Pro.
Check the 'Invert spatial relationship' check box when configuring the Select By Location tool
  1. Open an ArcGIS Pro project.
  2. In the Map tab on the ribbon, in the Selection group, click Select By Location.
  3. Check the Invert spatial relationship check box in the Select By Location window. Refer to ArcGIS Pro: How to use Select By Location for more information.
Configure the Select By Location tool and check the Invert spatial relationship check box to select the features that do not intersect or are not within the features of another layer on the map.
In the image below, points which do not intersect the polygon layer are selected (highlighted in light blue) on both the map and in the point layer attribute table.
The Select By Location tool selects the features that do not intersect or are not within the features of another layer on the map.
Select features using the Select By Location tool, then click the Switch button in the attribute table
  2. In the Map tab on the ribbon, in the Selection group, click Select By Location, and configure the Select By Location tool. Refer to ArcGIS Pro: How to use Select By Location for more information.
In the example displayed in the image below, the Relationship parameter is set to Intersect. Point features which intersect the polygon layer are selected on the map.
The Select By Location tool selects the intersecting features on the map.
  1. In the Contents pane, right-click the input layer and click Attribute Table.
  2. In the attribute table, click Switch Click the Switch button to switch the selection. to switch the selection.
In the image below, after clicking Switch, only point features that do not intersect the polygon layer are selected on the map.
Article ID: 000025744
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
