PROBLEM
When attempting to add or edit features using the Edit widget in ArcGIS Web AppBuilder, the template picker displays a blank window with the message, ‘Your account does not have permission to create or modify data. Or this web map does not contain any editable layers.’
The following are known causes of the issue:
Enable the editing capabilities of the hosted feature layer
In ArcGIS Online or Portal for ArcGIS, on the item details page, enable editing of the hosted feature layer. Refer to ArcGIS Online: Allow others to edit or Portal for ArcGIS: Allow others to edit for more information.
Enable editing of the editable feature layers at the web map level
In Map Viewer, enable editing of the feature layers.Note: This workflow is only applicable to feature layers with editing enabled at the layer level. Additionally, only administrators or the owner of the web map with the privilege to create content can enable editing of the feature layer in Map Viewer.
Enable editing of the layer in the Edit widget settings
Enable editing of the layer in Custom settings of the Edit widget in ArcGIS Web AppBuilder.
Update the member’s default role or custom role to enable the privilege to edit features in ArcGIS Online or Portal for ArcGIS
Note: Only an organization's administrator can perform the following workflows.
The image below shows the editable layers are displayed in the Edit widget template picker in ArcGIS Web AppBuilder.
Get help from ArcGIS experts
Download the Esri Support App
