PROBLEM
Unable to view layers in the Smart Editor widget template picker in ArcGIS Web AppBuilder
Last Published: February 22, 2022
In ArcGIS Web AppBuilder, the Smart Editor widget does not display editable layers in the template picker.
The image below shows the empty template picker in the Smart Editor widget.
The Smart Editor widget showing the editing template not displayed
Cause
The 'Update Only' check box is checked in the Smart Editor widget. This limits the layer's capability to only updating or modifying existing features, and renders it incapable of creating new features.
Solution or Workaround
Follow the instructions below to view the editable layers in the template picker.
  1. Open the Web AppBuilder application in editing mode and click the Widget tab.
  2. Click the Configure this widget icon of the Smart Editor widget.
  3. Uncheck the Update Only check box in the Layer Settings and click OK.
The Smart Editor widget with the unchecked Update Only check box
  1. Click Save, and click Launch to launch the application.
The image below shows the editable layers displayed in the Smart Editor widget template picker.
The Editing template displayed in the Smart Editor widget
Article ID:000023199
Software:
  • ArcGIS Web AppBuilder
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
