Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
Is there a way to add KMZ files to Web AppBuilder for ArcGIS?
Yes, there are two ways to add KMZ files to Web AppBuilder for ArcGIS. Although the Add Data widget in Web AppBuilder for ArcGIS does not provide the option to add KMZ files to the map, the KMZ files can be added via ArcGIS Online or Google Earth. To do so, follow one of the options described below:
Add the KMZ file to ArcGIS Online
Note: KMZ files are the compressed, zipped versions of KML files.
Convert the KMZ file to a KML file in Google Earth
Note: For more detailed steps on how to add data to ArcGIS Online and Web AppBuilder for ArcGIS, refer to ArcGIS Online: Add items and Web AppBuilder for ArcGIS: Use the Add Data widget.
Last Published: 6/25/2019
Article ID: 000020012
Software: ArcGIS Web AppBuilder Current
