PROBLEM
Unable to add a KMZ file to ArcGIS Online
Attempting to add a KMZ file to ArcGIS Online may return the following error message.
Error:
Unable to load KML: Unzipped KML file is too large. <value> bytes exceeds the allowable maximum of 10485760 bytes.
KMZ error
A KMZ file is a compressed version of a KML file, which may include images.
Cause
This is a limitation in ArcGIS Online. When a KML file larger than 10 MB is compressed, it cannot be added to ArcGIS Online.
Solution or Workaround
As a workaround, convert the KMZ file to a feature layer using the KML to Layer tool in ArcMap, and publish the output feature class and the layer file to ArcGIS Online. For more details, refer to the following web help document, Publish from ArcMap.
As an alternative, convert the KMZ file to a CSV file to create a point feature class. Export the point feature class to a shapefile, and add it to ArcGIS Online.
Article ID:000019435
Software:
  • ArcGIS Online
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
