When editing in ArcGIS Pro, the snapping tool is not working.
Cause
The following are possible causes for the issue:
- The snapping option is disabled.
- Snapping is done on an unfinished feature. A sketch is not a feature until it is finished.
- Snapping cannot be done on arc segments when the editing is constrained to parallel or perpendicular segments. This behavior is a known issue in ArcGIS Pro versions 2.2 and earlier.
Solution or Workaround
Described below are possible solutions depending on the cause:
