HOW TO
In ArcGIS Pro, issues related to application failure and crashing can occur if the registry entry is corrupted. Performing a soft reset resolves the issue by closing applications and clearing data in the RAM, in contrast to a hard reset, whereby user data are removed and the device is restored to its factory settings. This article describes the workflow to perform a soft reset in ArcGIS Pro.
Perform a soft reset by renaming the roaming and local profiles, and editing the Windows registry for ArcGIS Pro applications.
Note: If there are concurrent licenses on the machine, return any borrowed licenses before performing the workarounds below. For more information on borrowed licenses, refer to ArcGIS Pro: Start ArcGIS Pro with a Concurrent Use license.
Rename the roaming and local profiles
Note: The AppData folder is hidden. To display hidden folders, refer to Microsoft Windows Support: Show hidden files.
C:\Users\YourUsername\AppData\Roaming\ESRI
C:\Users\YourUsername\AppData\Local\ESRI
Note: This information applies to ArcGIS Pro 2.9 and prior. At ArcGIS Pro 3.0, this folder is ArcGISPro_StrongName...
Make edits in the Registry Editor
Warning: Editing the Windows registry requires administrator privileges on the machine and must only be done as a last resort. Perform a backup of the registry or machine before proceeding with the steps below. Consult a qualified computer systems professional, if necessary. Esri is not liable for incorrect modifications following these instructions. User discretion is advised.
Launching ArcGIS Pro recreates all the renamed folders and registries, and allows the application to launch smoothly.
Article ID: 000027631
Get help from ArcGIS experts
Download the Esri Support App
