Support Resource
ArcGIS Online is a powerful platform that enables usage of a wide range of field types. However, not all field types (data types) are compatible with every application within the ArcGIS ecosystem. This article identifies which field types to avoid, best practices for field type selection, and the alternatives to ensure smooth functionality across various applications.
Certain field types in ArcGIS Online may not be fully supported across all applications, leading to potential issues. Here are some key field types to be cautious about. Note that these field types were made compatible with ArcGIS Pro at version 3.2: Problem: Features Are Not Displayed in ArcGIS Field Maps (esri.com)
To ensure compatibility and functionality across various ArcGIS applications, follow these best practices:
When you need to avoid certain field types, consider these alternatives:
The Date Only field type, introduced in ArcGIS Pro 3.2, is under consideration for future compatibility enhancements. There are existing enhancement requests for ArcGIS Dashboard to support this field type. Staying informed about these updates will help you make better decisions regarding field type usage.
Choosing the right field types in ArcGIS Online is crucial for ensuring compatibility and functionality across various applications. By following best practices and avoiding complex field types, you can create more robust and reliable GIS data. Always test your data in all intended applications and stay updated with the latest from Esri to make the most of your GIS projects.
Article ID: 000033765
Get help from ArcGIS experts
Start chatting now
