ERROR
Unable to publish the survey: HTTP 504 Unknown Error
Last Published: January 24, 2025
Error Message
After creating the survey, and attempting to publish it from Portal for ArcGIS using the ArcGIS Survey123 website, the following error is returned:
When checking from the browser's Developer tools, on the Response tab, the following error may be displayed.
"504 Gateway Timeout","Error from Cloudfront"
Cause
This is not a Survey123 error. The error is on the Cloudfront side and users must investigate the issue with the help of their IT department.
Solution or Workaround
There are two approaches to resolve this issue:
  • Work with your IT network team to resolve any web application firewall issues.
  • Use ArcGIS Survey123 Connect as an alternative to publish the survey.
Article ID: 000034416
Software:
  • Portal for ArcGIS
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
