ERROR
Unable to log in using IDP. 'NAME_ID' not found in SAML response for AD FS
First Published: July 21, 2021
Error Message
When using the Active Directory Federation Services (AD FS) SAML IDP, the following error is returned when trying to log in to ArcGIS Enterprise portal via SAML logins:
Unable to log in using Idp. 'NAME_ID' not found in SAML response
Cause
The SAML NameID attribute is missing from the <Subject> element of the SAML assertion response.
Solution or Workaround
  1. Open the AD FS management console.
  2. Select Relying Party Trusts. In the Relying Party Trusts window, select the SP corresponding to your enterprise portal.
  3. On the Actions tab, click Edit Claim Issuance Policy (ADFS 4) or Edit Claim Rules (ADFS 3), and select the Issuance Transform Rule and click Edit Rule.
  4. In the Edit Rule window, click View Rule Language.
  5. Verify that the Name ID attribute is sent using the type: https://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier
  6. If this attribute is missing, add a new claim for the Name ID attribute. For the Outgoing claim type, choose the value Name ID from the drop-down list of options.
Article ID: 000026098
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
