PROBLEM
The Delete and Rename options are disabled for a feature class in a geometric network or network dataset
First Published: May 5, 2016
For feature classes participating in a geometric network or network dataset, the Delete and Rename options are disabled in the context menu and the feature classes cannot be modified or removed.
Cause
This is expected behavior. The management of network feature classes is more restrictive as opposed to managing simple feature classes. While a network feature class alias can be changed, its name cannot. Deleting a network feature class is also more difficult compared to deleting simple feature classes.
Solution or Workaround
To rename or delete source feature classes, the network dataset must be deleted or dropped. Once the modification or deletion of the participating feature class is done, the network can be re-built.
There is a special case for empty feature classes in a geometric network. These can be deleted using the Remove Empty Feature Class From Geometric Network geoprocessing tool.
For more information, refer to the following documentation:
ArcGIS Help: Managing the geometric network
ArcGIS Help: Removing network sources
Article ID: 000012558
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
