HOW TO
When using ArcGIS Field Maps on Android 11, you may not be able to access the device’s external storage when connecting it to a computer. The files stored externally on the microSD card still exist, they just won’t appear in the computer’s file explorer. This prevents copying (sideloading) mobile map packages (MMPKs) and basemaps to the device.
To sideload files to your device (and access existing files) using external storage on Android 11, you must connect the microSD card directly to the computer using a card reader. The full procedure is detailed below:
Note: If either folder does not exist, you can manually create it.
The MMPK or basemap is ready to use in ArcGIS Field Maps.
Article ID: 000026920
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
