HOW TO
Rename the ST_Geometry points' Oracle LOB segment
First Published: May 5, 2016
Summary
Instructions provided describe how to rename the ST_Geometry points' LOB segment.
If the LOB segment name is not specified during the creation of the ST_Geometry attribute, the LOB segment name is created automatically by Oracle. Without an identifiable name, it may be difficult to identify which LOB segments are impacted by performance. By providing a LOB segment name, the user controls the naming convention and can specify a name that relates to the table name.
Procedure
  1. Use Oracle's ALTER TABLE command the to rename a LOB segment.
    Code:
    SQL> ALTER TABLE streets
    2 MOVE LOB(shape.points) STORE AS streets_lob_seg;
    Table altered.
    When Oracle moves the physical storage of the LOB segment and table, all existing indexes are marked as unusable.
    Code:
    SQL> SELECT index_name, status
    2 FROM user_indexes
    3 WHERE table_name = 'STREETS';
    INDEX_NAME STATUS
    STREET_NAME_IDX UNUSABLE
    R45_SDE_ROWID_UK UNUSABLE
    SYS_IL0000346092C00038$$ VALID
    A9_IX1 UNUSABLE
  2. Each index must be rebuilt so that it is valid. Enter the code below to alter the index:
    Code:
    SQL> ALTER INDEX street_name_idx REBUILD;
  3. Optional: Gather new table statistics.
    See Oracle's documentation for additional information.
Article ID: 000009516
Software:
  • Legacy Products
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
