PROBLEM
The ArcGIS Field Maps app allows mobile workers to use the app in the field to collect location and fill out forms. In some cases, a web map containing editable layers and enabled for ArcGIS Field Maps mobile use is not editable in the mobile app. When searching for the web map in the app, it only appears when selecting the 'Read-only' option.
Only the 'Use in ArcGIS Field Maps Mobile' option is enabled, while the 'Use in ArcGIS Collector' option is disabled in the web map settings.
To enable web map editing in ArcGIS Field Maps app, enable the Use in ArcGIS Collector and Use in ArcGIS Field Maps Mobile settings.
Note: If the Use in ArcGIS Collector check box is not available, refer to Problem: The Use in ArcGIS Collector option is unavailable in a web map’s settings.
Article ID: 000025697
Get help from ArcGIS experts
Start chatting now
