PROBLEM
In ArcGIS Enterprise, attempting to view a survey in ArcGIS Survey123 fails and returns the following error message:
Error: The survey is not accessible or does not exist. Please ensure the signed in user (<username>) can access this survey and that the survey link is correct.
Register the correct ArcGIS Survey123 domain in the ArcGIS Server Administrator Directory. Refer to ArcGIS Server: Restrict requests from JavaScript applications for instructions. In Step 4, for AllowedOrigins, register the following domain:
https://survey123.arcgis.com
Configure a correct hosting server and register the hosting server in Portal for ArcGIS. Refer to Portal for ArcGIS: Configure a hosting server for instructions.
In Portal for ArcGIS, reassign the survey folder including the survey form and the survey hosted feature layer to the new owner of the survey. Refer to Portal for ArcGIS: Change owner for instructions.
Note: To prevent the survey form and the survey hosted feature layer from being deleted, enable the delete protection for the items. Refer to Portal for ArcGIS: Enable delete protection for instructions.
In Internet Information Services (IIS) Manager, remove duplicate headers. Refer to the solution section of this article, Error: The survey does not exist or is not accessible for instructions.
Grant permissions to the default ArcGIS Enterprise folders for the ArcGIS Server Windows account. Refer to ArcGIS Enterprise: Permissions to grant to the ArcGIS Server account for more information.
Contact the organization’s IT department to add an exception for the ArcGIS Survey123 URL to the firewall. Add the following URL:
Contact the organization’s IT department to import the root certificate to the ArcGIS Enterprise environment. Refer to Portal for ArcGIS: Import a certificate into the portal for more information.
Troubleshoot ArcGIS Data Store to validate ArcGIS Data Store. Refer to Portal for ArcGIS: Troubleshoot ArcGIS Data Store for instructions.
Article ID: 000031830
Get help from ArcGIS experts
Start chatting now
