HOW TO
Validate ArcGIS Data Store
First Published: November 15, 2019
Last Published: March 10, 2026
Summary
This article describes the three different methods ArcGIS Enterprise administrators can employ to validate ArcGIS Data Store, and they are described as follows:
  • Validate via ArcGIS Server Manager
  • Validate via the Validate Data Store option in the ArcGIS Server admin endpoint
  • Validate via JSON in the ArcGIS Server admin endpoint
Procedure
  1. Log in to ArcGIS Server Manager with an administrator account.
  2. Navigate to Site > GIS Server > Data Stores.
  3. Check the relevant data stores check boxes, and click Validate. A successfully validated data store is marked by a green check mark.
GIS Server Data Stores window
  1. Log in to the ArcGIS Server admin endpoint with an administrator account.
  2. Navigate to the following path:
Relational store: Home > data > items > enterpriseDatabases > AGSDataStore_ds_datastoreID > machines > machine_name > validate
Object store: Home > data > items > cloudStores > AGSDataStore_objectstore_oz_datastoreID > machines > machine_name > validate
Tile cache data store: Home > data > items > nosqlDatabases > AGSDataStore_nosqldb_tcs_datastoreID > machines > machine_name > validate
Spatiotemporal big data store: Home > data > items > nosqlDatabases > AGSDataStore_bigdata_datastoreID > machines > machine_name > validate
Graph store: Home > data > items > nosqlDatabases > AGSDataStore_graph_datastoreID > machines > machine_name > validate
Deployments upgraded to ArcGIS Enterprise 11.5 from earlier versions may retain an existing tile cache data store. Fresh installations of ArcGIS Enterprise 11.5 do not include the tile cache data store. ArcGIS Enterprise 11.5 is the final release to support this data store type. Refer to Deprecation: ArcGIS Data Store Tile Cache Data Store Deprecation Notice for additional information.
  1. Click Validate.
Relational store: Home > data > items > enterpriseDatabases > AGSDataStore_ds_datastoreID > edit
  1. Copy the JSON from the Item field.
Home > data > validateDataItem
  1. Paste the JSON in the Item field.
  2. Select JSON from the Format drop-down menu. Click Validate. Successfully validating the data store loads a new page displaying {"status": "success"}.
  3. Repeat Steps 1 through 6, substituting the path used in Step 2 with the appropriate data store paths below to validate the object store,  tile cache data store, spatiotemporal big data store, and graph store:
Object store: Home > data > items > cloudStores > AGSDataStore_objectstore_oz_datastoreID > edit
Tile cache data store: Home > data > items > nosqlDatabases > AGSDataStore_nosqldb_tcs_datastoreID > edit
Spatiotemporal big data store: Home > data > items > nosqlDatabases > AGSDataStore_bigdata_datastoreID > edit
Graph store: Home > data > items > nosqlDatabases > AGSDataStore_graph_datastoreID > edit
Article ID: 000022348
Software:
  • ArcGIS Data Store
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
