PROBLEM
Unable to validate the tile cache data store in ArcGIS Server Manager
First Published: January 22, 2024
Last Published: January 22, 2024
In ArcGIS Server Manager, after modifying or upgrading an ArcGIS Data Store machine, attempts to validate the tile cache data store fail, as shown in the image below.
The data stores status on the ArcGIS Server Manager page.
Cause
The tile cache data store is not running when checking the data store information using the describedatastore utility in the Command Prompt of the ArcGIS Data Store machine. The image below shows the data store status in the Command Prompt is Stopped.
The data store information in the Command Prompt.
Solution or Workaround
To validate the tile cache data store, restart the ArcGIS Data Store machine to run the tile cache data store again. Refer to How To: Start and stop ArcGIS Server machines using the ArcGIS Server Administrator Directory for instructions and more information.
The image below shows the tile cache data store successfully validated in ArcGIS Server Manager.
Article ID: 000031687
Software:
  • ArcGIS Data Store
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
