PROBLEM
Unable to snap features in ArcGIS Pro
When editing in ArcGIS Pro, the snapping tool is not working.
Cause
The following are possible causes for the issue:
  • The snapping option is disabled.
  • Snapping is done on an unfinished feature. A sketch is not a feature until it is finished.
  • Snapping cannot be done on arc segments when the editing is constrained to parallel or perpendicular segments. This behavior is a known issue in ArcGIS Pro versions 2.2 and earlier.
Solution or Workaround
Described below are possible solutions depending on the cause:
Article ID: 000019578
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
