PROBLEM
Unable to select multiple features using the Shift key in the ArcGIS Experience Builder Select widget
First Published: April 23, 2025
Last Published: December 3, 2025
In ArcGIS Experience Builder, using the Select widget with the Shift key to select multiple features on a Map widget results in only the last clicked feature being selected.
Cause
This is expected behavior. When 'Attribute selection' is enabled in the Select widget's settings, the widget switches to an attribute-query workflow and limits interactive map selection to 'New selection' only. Refer to ArcGIS Experience Builder: Usage notes for more information.
Solution or Workaround
Disable 'Attribute selection'
  1. Open the ArcGIS Experience Builder web experience.
  2. Click the Select widget to open the Select pane.
  3. In the Select pane, on the Content tab, click the map to open the Customize layers panel. In this example, the helloworld_01 map is selected.
Image of the selected map and the Customize layers panel.
  1. In the Customize layers panel, navigate and disable the Attribute selection setting.
Image shows the disabled Attribute selection setting.
The image below shows multiple features selected using the Shift key in ArcGIS Experience Builder after disabling the 'Attribute selection' setting.
Image shows multiple features selected in ArcGIS Experience Builder.
Use the Select tool
Optionally, use the Select tool from the Map widget in the ArcGIS Experience Builder web experience. Refer to How To: Select multiple features within the map in ArcGIS Experience Builder for instructions.
Article ID: 000035827
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
