HOW TO
Select multiple features within the map in ArcGIS Experience Builder
First Published: December 19, 2023
Last Published: February 1, 2024
Summary
Interactively selecting multiple features allows for the emphasis of a specific set of features for use in data exploration or analysis. Selected features can be used to calculate statistics, view attributes, edit, or define the features within a layer. This article explains how to select multiple features in ArcGIS Experience Builder.
Procedure
  1. Open the ArcGIS Experience Builder project and navigate to the Insert widget panel.
  2. Under Map centric, drag and drop the Map widget onto the canvas.
The Map panel
  1. In the Map panel, click Select map to select a web map for the first Map widget. If necessary, click Add new data to add web maps from ArcGIS Online.
Select map and Add new data.
  1. On the Content tab, under Tools, toggle Select on.
The selected web map and Select tool option
  1. Click Save to save the experience, and click Publish to publish the experience to ArcGIS Online.
The builder window ribbon
  1. To view the published experience, click More from the toolbar at the top of the builder window and click View published item.
The builder window toolbar
  1. To select multiple feature in the published experience, click the drop-down button of the Selection tool and click the required selection method. After selecting, double-click the canvas to view the highlighted features. Refer to ArcGIS Experience Builder: Map widget.
The image below shows multiple features selected in ArcGIS Experience Builder.
Multiple features selected in the widget
Article ID: 000031516
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
