PROBLEM
In ArcGIS Pro, a page layout is a collection of map elements including one or more map frames, a legend, a north arrow, a scale bar, a title, and descriptive text organized on a page designed for map printing. Refer to ArcGIS Pro: Layouts in ArcGIS Pro for more information.
In some instances, the elements are not selectable for editing when using the Select option in the Elements group from the Layout tab in ArcGIS Pro.
The image below shows the elements not selected when using the Select option in ArcGIS Pro.
Unlock the element item
In ArcGIS Pro, in the layout view, click the Lock
button next to the item in the Contents pane to unlock the element.
Note: Alternatively, double-click the item in the Contents pane to open the Element pane. Under the Options section, click the General drop-down arrow and uncheck the Locked check box.![]()
Set the Selection combination mode
Clear the cache data
The image below shows the desired layout elements selected in ArcGIS Pro.
Article ID: 000032321
Get help from ArcGIS experts
Start chatting now
