HOW TO
Delete ArcGIS Pro temporary files
First Published: December 9, 2021
Last Published: July 20, 2023
Summary
In some instances, temporary files are not automatically removed by ArcGIS Pro. If these files are allowed to accumulate, they may result in slow performance of geoprocessing tasks and other ArcGIS Pro functions. Clearing the temporary files regularly helps avoid performance issues that temporary file build-up may cause.
Procedure
To delete temporary files in ArcGIS Pro, complete the workflow below.
  1. On the machine, navigate to the following folder in File Explorer:
C:\Users\<username>\AppData\Local\Temp
By default, the AppData folder is hidden. Refer to Microsoft Windows: View hidden files and folders in Windows for instructions to display hidden folders.
  1. Delete the temporary files containing ArcGISPro in the file name.
Esri recommends clearing the cache regularly in ArcGIS Pro. To do this, navigate to ArcGIS Pro Settings > Options > Display > Local cache, check the Clear cache check box and click OK. However, this is not located in the Temp directory, but the Local Caches directory in C:\Users\<username>\AppData\Local\ESRI\Local Caches.
Article ID: 000026912
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
