PROBLEM
Unable to select graphics on a map in ArcGIS Pro
First Published: August 12, 2022
Last Published: March 19, 2024
Labels can be converted to graphics for a single layer or the entire map. In some instances, after converting labels to graphics, the graphics are not selectable for editing when using the Select option in the Edit group from the Graphics tab in ArcGIS Pro.
The image below shows the desired graphics are not selected on the map with the Select option in ArcGIS Pro.
The desired graphics not being selected on the map by the Select option in ArcGIS Pro.
Cause
  • The graphics layer is not enabled.
  • The ‘Remove from the current selection’ or ‘Select from the current selection’ option is selected under the ‘Selection combination mode’ section.
Solution or Workaround
Enable the graphics layer
In ArcGIS Pro, ensure the graphics layer is checked for visibility in the Contents pane.
In ArcGIS Pro, click the Graphics tab and select the desired graphics layer under Target layer. Refer to ArcGIS Pro: Work with graphics layers for more information.
The desired graphics layer under Target layer being selected.
Alternatively, in the Contents pane, click the List By Selection tab, and check the graphics layer check box to enable the graphics layer. Restart ArcGIS Pro, if necessary.
The image of the graphics layer being enabled under the List By Selection tab in the Contents pane.
Set the Selection combination mode
  1. In ArcGIS Pro, on the ribbon, click the Project tab > Options.
  2. In the Options window, click Selection under Application.
  3. Under Selection combination mode, select Create a new selection or Add to the current selection.
  4. Click OK and refresh the map.
The 'Selection combination mode' options.
The map shows the desired graphics are selected in ArcGIS Pro.
The animation shows the desired graphics are being selected on the map in ArcGIS Pro.
Article ID: 000028178
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
