PROBLEM
Unable to select certain features in a map in ArcGIS Field Maps
Last Published: September 2, 2024
In the ArcGIS Field Maps mobile app, attempts to select certain features from a layer in a web map fail.
The image below shows a polygon feature selected instead of the intended point feature.
The image of the polygon feature being selected when clicking a point feature.
Cause
  • Pop-ups for the hosted feature layer are not enabled in the existing web map.
  • A new hosted feature layer is added to the web map through ArcGIS Field Maps Designer instead of ArcGIS Online Map Viewer. So, the newly added features of the hosted feature layer cannot be selected in the ArcGIS Field Maps mobile app. This is a known limitation, as addressed in BUG-000153048.
Solution or Workaround
Ensure the editing capabilities are enabled in the hosted feature layers in ArcGIS Online. Refer to ArcGIS Online: Manage hosted feature layer editing for more information.
Enable the pop-ups
Enable the pop-ups of the hosted feature layer in the web map. Refer to ArcGIS Online: Enable and remove pop-ups for instructions. In Step 4, toggle Enable pop-ups on.
The image of the pop-ups being enabled in the web map.
Re-save the new hosted feature layer
In ArcGIS Online, open the newly created hosted feature layer's item details page, and click the Visualization tab > Save. Refresh the web map in the ArcGIS Field Maps mobile app.
The image of the newly created hosted feature layer being saved in ArcGIS Online.
Create a new web map
In ArcGIS Online, create a new web map and add the new hosted feature layers.
The image below shows the feature point selected as intended.
The image of the feature point being selected when clicking the intended point feature.
Article ID: 000033416
Software:
  • ArcGIS Online
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
