PROBLEM
Unable to run the Train Deep Learning Model tool in an offline environment
Last Published: October 22, 2020
When using the Train Deep Learning Model tool in an offline environment, it fails with the following error:
Error:
Downloading: "https://download.pytorch.org/models/resnet34-333f7ec4.pth" to C:\Users\Administrator/.cache\torch\checkpoints esnet34-333f7ec4.pth
Image of the error when running the Train Deep Learning Model tool.
Cause
This issue occurs because the tool needs to download a pytorch (.pth) file that it requires to run.
Solution or Workaround
To use the Train Deep Learning Model tool in an offline environment, follow the steps below:
  1. In an online environment, navigate to the following URL in a browser to download the required .pth file.
  1. Transfer the downloaded file into the offline environment, and save the file in the following location:
Image of the downloaded file saved in the offline environment.
  1. Run the tool. It runs successfully since the required .pth file is saved within the folder that the tool refers to.
Article ID: 000024360
Software:
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
