PROBLEM
ArcGIS Living Atlas of the World is an evolving collection of ready-to-use global geographic information. It includes imagery, basemaps, apps, and layers that are accessible in ArcGIS Online. However, when using an ArcGIS Living Atlas layer in ArcGIS Pro, publishing the layer as a hosted feature layer to ArcGIS Online fails, and the following error and warning messages are returned:
Error: 00102: Map does not contain a required layer type for web feature layer
Warning: 24078: Layer’s data source is not supported: <value>
This issue occurs when the ArcGIS Living Atlas layers are not stored as geodatabase feature classes in ArcGIS Pro. Sharing of non-geodatabase data is not supported in ArcGIS Pro.
In ArcGIS Pro, convert the ArcGIS Living Atlas layer as a geodatabase feature class, and publish it as a web layer to ArcGIS Online.
to specify the location of the output feature class.
The image below shows the layer published successfully to ArcGIS Online as a web layer in ArcGIS Pro.
Article ID: 000026249
Get help from ArcGIS experts
Start chatting now
