PROBLEM
The option to share items publicly is unavailable in ArcGIS Online
First Published: April 9, 2020
When attempting to share content, such as a web map, publicly in ArcGIS Online, the option is unavailable.
Option to share not available
Cause
The following are known causes:
  • The member’s default role or custom role has insufficient privileges.
  • Access and permissions to share content publicly are restricted in the security settings.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Only an organization's administrator can perform these steps.
Enable sharing privileges for the member's role
A role defines the set of privileges assigned to a member. Privileges are assigned to members through a default role or a custom role.
Edit role
Configure the security settings
Configure the security settings to allow members to share content publicly. Refer to ArcGIS Online: Configure security settings for more information.
Article ID: 000022952
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
