PROBLEM
The default file geodatabase is empty in ArcGIS Pro
First Published: February 21, 2024
Last Published: February 21, 2024
In ArcGIS Pro, an existing default file geodatabase is empty even though it is supposed to contain datasets. The image below displays an empty current geodatabase with features missing in the Catalog pane.
The ArcGIS Pro Catalog pane
Cause
  • The file geodatabase has been moved from the project folder.
  • The file geodatabase has been renamed in File Explorer.
In either scenario, ArcGIS Pro autogenerates a new, empty default file geodatabase, as is required in every ArcGIS Pro project.
Solution or Workaround
Relocate the original file geodatabase into the project home folder
  1. Open the ArcGIS Pro project. In the Catalog pane, right-click the file geodatabase and click Show In File Explorer.
  2. Close ArcGIS Pro.
  3. In the File Explorer window, locate, copy, and paste the original file geodatabase into the project home folder.
  4. In the Replace or Skip Files window, click Replace the files in the destination.
  5. Reopen the project in ArcGIS Pro.
Rename the file geodatabase to the default name
  1. Open the ArcGIS Pro project. In the Catalog pane, right-click the file geodatabase folder and click Show In File Explorer.
The Show In File Explorer option in the Catalog pane
  1. Close ArcGIS Pro.
  2. Delete the autogenerated file geodatabase folder in File Explorer.
The autogenerated file geodatabase in File Explorer
  1. Rename the file geodatabase to the default name. In this example, the original file geodatabase name has been changed from 'Change_test5_default gdb.gdb' to 'test5_default gdb.gdb'.
The renamed file geodatabase in File Explorer
  1. Reopen the project in ArcGIS Pro.
The image below shows the dataset as expected under the default file geodatabase in the Catalog pane.
Article ID: 000031761
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
