PROBLEM
In ArcGIS Pro, running the Clip tool generates an empty output, and returns the following warning message:
Warning: WARNING 000117: Warning empty output generated
Depending on the cause, use either one of the following solutions:
Repair broken geometry before using the Clip tool
Ensure the geometry layer overlaps one another
To circumvent the error, ensure the features in the desired layers overlap one another. The following image shows an example of the overlapped features from different layers.
Article ID: 000026480
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
