PROBLEM
The Analyze and Publish options are disabled when sharing layers from ArcGIS Pro to ArcGIS Online
First Published: September 18, 2023
Last Published: July 22, 2026
In ArcGIS Pro, when attempting to share layers to ArcGIS Online, the Analyze and Publish options are disabled as shown in the image below.
The Share As Web Layer pane is to be configured but the Analyze and Publish options are disabled.
Cause
Solution or Workaround
Only an organization's default administrator or a member with administrative privileges can perform the following workflow.
Change the member’s role with the privilege to publish layers
In ArcGIS Online, change the member’s role to Publisher, Facilitator, or Administrator. Refer to ArcGIS Online: Change member roles for instructions.
Configure the member’s custom role to grant the privileges to publish layers
In ArcGIS Online, configure the member’s custom role by enabling the privileges to publish the preferred layers in the Content section under the General privileges settings. Refer to ArcGIS Online: Configure member roles for more information and instructions.
List of layers that can be published under the General privileges settings.
Purchase more credits for the ArcGIS Online organization
In ArcGIS Online, purchase additional credits for the organization from the Esri store to enable publishing layers.
Article ID: 000031107
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
