PROBLEM
North arrow is displayed incorrectly when exported to PDF
Last Published: March 14, 2023
In ArcGIS Pro, when exporting a layout with a north arrow to a PDF file, the north arrow symbol is displayed incorrectly as shown in the image below.
A PDF of a map layout with a north arrow on an Android mobile device.
Cause
The north arrow symbols provided in ArcGIS Pro is a character from a font. When a map layout is exported to PDF, the PDF viewer used to open the exported PDF file does not contain the font that the symbol uses. Instead, it references the font to one available in their databases, causing the north arrow symbol to display incorrectly.
Solution or Workaround
Embed the fonts before exporting the layout to a PDF file to resolve the issue.
  1. Open the ArcGIS project.
  2. Click the Layout tab to activate the layout view. The tab color turns blue.
  3. In the layout view, on the Share tab, click Export Layout.
  4. In the Export Layout pane, on the Properties tab, expand Fonts and check the Embed fonts check box.
The Export Layout pane in ArcGIS Pro.
  1. Click Export.
The image below shows the north arrow being correctly displayed in a PDF file exported from ArcGIS Pro.
A PDF of a map layout with the north arrow on an Android mobile device.
Article ID: 000029485
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
