PROBLEM
Loading a MrSID raster into a geodatabase in ArcGIS Pro is time consuming
Last Published: May 11, 2021
Loading a MrSID raster into a geodatabase takes a longer time to load compared to loading the same raster data in a different format.
Cause
MrSID raster datasets are a highly compressed raster format with a lossy compression algorithm. When loading MrSID datasets into a geodatabase, they are first uncompressed to get to the actual pixel values before being loaded into the geodatabase. This results in a long processing time, and may require an unanticipated amount of disk space.
Solution or Workaround
An alternative is to convert the MrSID raster dataset into a different raster format, such as the TIFF format. Follow these steps to do this:
  1. On the ArcGIS Pro top ribbon, click the Analysis tab, and click Tools.
  2. In the Geoprocessing pane, search for and click Raster To Other Format (Conversion Tools)
  3. In the Raster To Other Format geoprocessing pane, for Input Rasters, browse for and select the MrSID raster dataset to convert.
  4. For Output Workspace, select the folder where the raster dataset is exported to.
  5. For Raster Format, select the raster format the MrSID raster dataset is converted to from the drop-down menu. For this example, it is 'TIFF'.
  6. Click Run.
The Raster To Other Format geoprocessing pane with the SID raster dataset set as the input raster to be converted to the TIFF format.
  1. Import the new raster into the geodatabase.
    2. In the Geoprocessing pane, search for and click Raster To Geodatabase (Conversion Tools).
    3. For Input Rasters, browse for and select the newly converted raster dataset.
    4. For Output Geodatabase, specify the geodatabase the raster dataset is imported into.
    5. Click Run.
The Raster To Geodatabase geoprocessing pane with the converted raster selected to be imported into a selected output geodatabase.
Article ID: 000025180
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
