PROBLEM
Legend item sizes are retained when resizing the legend in an ArcGIS Pro layout
Last Published: February 4, 2025
In ArcGIS Pro, legend item sizes are retained although the legend is resized in the layout view, as shown in the image below.
The comparison of the legend items before and after resizing in an ArcGIS Pro layout
Cause
The legend fitting strategy is set to 'Adjust columns'. Therefore, the legend item sizes remain unchanged when resizing the legend. Refer to ArcGIS Pro: Adjust the columns for more information.
Solution or Workaround
Convert the legend to graphics
  1. Open the ArcGIS Pro layout.
  2. In the Contents pane, right-click Legend and click Convert to Graphics.
The Convert to Graphics option
  1. In the Contents pane, right-click Legend and click Ungroup.
The Ungroup option
  1. In the Contents pane, under Drawing Order, expand the desired legend items group layer and select the text item layer.
  2. On the Text ribbon tab, in the Text Symbol group, specify the preferred font size. Optionally, click Increase Font Size or Decrease Font Size to adjust the font size incrementally.
The Text Symbol group in the Text tab
  1. Repeat Step 4 and select the symbol item layer.
  2. On the Graphic ribbon tab, in the Symbol group, specify the preferred font size.
The image below shows the resized legend, converted to graphics.
The resized legend converted to graphics
Change the legend fitting strategy to 'Adjust columns and font size'
This workflow is applied only when shrinking the legend or restoring it to its original size.
  2. In the Contents pane, double-click Legend to open the Element pane.
  3. In the Element pane, click the Legend Arrangement Options tab.
  4. Under Fitting Strategy, select Adjust columns and font size from the drop-down list.
  5. Drag the legend to resize the text to the preferred font size. Optionally, specify the Minimum font size value to ensure the text remains legible, preventing it from shrinking to an unreadable size.
The Fitting Strategy option in the Element pane
The image below shows the legend with the preferred font size after resizing the legend in ArcGIS Pro.
The legend with the preferred font size when resizing the legend in ArcGIS Pro
Change the legend fitting strategy to 'Adjust frame'
  1. Apply Steps 1 through 3 from the previous workflow.
  2. Under Fitting Strategy, select Adjust frame from the drop-down list.
  1. On the Legend ribbon tab, in the Text Symbol group, specify the preferred font size. Optionally, click Increase Font Size or Decrease Font Size to incrementally adjust the font size.
The Text Symbol group in the Legend tab
The image below shows the legend with the preferred font size appropriately sized for the legend in ArcGIS Pro.
The legend with the preferred font size appropriately sized for the legend in ArcGIS Pro
Article ID: 000034498
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
