PROBLEM
The legend displays a bracketed red ellipsis in the map layout in ArcGIS Pro
Last Published: March 24, 2021
Adding a legend component to a map layout provides a visual description of the symbols used in the map. In some cases, when adding and editing a legend in the map layout, the legend displays a bracketed red ellipsis instead of the layer name in the Contents pane.
Map layout of trails in the Zion National Park region displaying a legend with red ellipsis in ArcGIS Pro.
Cause
The legend's text item representing the layer name is longer in size than the legend.
Solution or Workaround
Increase the size of the legend in the Layout view
  1. In the Layout view, click the legend. The legend frame appears.
  2. Click and drag one of the resize handles on the vertical and horizontal sides of the legend frame to enlarge the legend. The layer's symbology name is displayed in the legend.
The legend of the Trails in the Zion National Parks Region map layout displaying a red ellipsis.
The legend of the Trails in the Zion National Parks Region map layout displaying the full layer symbology name.
Increase the size of the legend in the Legend properties window
  1. In the Layout view, right-click the legend, and click Properties. The Element pane displaying the Legend window opens.
  2. In the Placement section, under Size, increase the Width and Height values.
The Legend window containing the Width and Height parameters for the legend size.
Shorten the layer name
  1. In the Contents pane, under Map, right-click the feature layer, and click Properties. The Layer Properties: <layer_name> window opens.
  2. In the Layer Properties: <layer_name> window, click the General tab.
  3. In the Name section, edit the layer name to shorten it. In this example, the layer is renamed Trails.
  4. Click OK.
The layer properties window displaying the General tab containing the layer's properties such as Name. Click OK after renaming the layer.
The image below shows the legend with the shortened layer symbology name in the Layout view.
The map layout of Trails in the Zion National Parks displaying the legend with the full description for the layer symbology.
Article ID: 000025314
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
