PROBLEM
Labels do not display correctly in ArcGIS Dashboards
Last Published: August 4, 2021
In ArcGIS Dashboards, the labels in the map display incorrectly compared to the labels displayed in the web map in ArcGIS Online Map Viewer.
The following image shows the example of the labels in ArcGIS Online Map Viewer.
Labels displayed in ArcGIS Online Map Viewer.
The following image shows the example of the labels in ArcGIS Dashboards.
Labels display incorrectly in ArcGIS Dashboards.
Cause
  • There are multiple feature layers turned on for labeling in the web map in ArcGIS Online Map Viewer.
  • A date field is used for the labeling in ArcGIS Online Map Viewer.
Solution or Workaround
Choose one of the options below depending on the cause to resolve the issue.
Toggle off labeling for other feature layers
  1. In ArcGIS Online Map Viewer, open the map containing the feature layers.
  2. On the Contents toolbar on the left side, click Layers.
Opening the Layers list from the Contents toolbar.
  1. In the Layers pane, select the layer to be excluded from labeling.
  2. On the Settings toolbar on the right side, click Labels.
Configuring the labels' settings from the Settings toolbar.
  1. In the Label features pane, toggle off Enable labels.
Toggle off the Enable labels option in the Label features pane.
  1. Repeat steps 3 to 5 in other layers if needed.
  2. Save the web map.
  3. On the Contents toolbar on the left side, click More > Create app.
Create a new dashboard app from the Contents toolbar.
  1. Select Dashboards to create a new dashboard or refresh the existing dashboard in ArcGIS Dashboards.
Selecting Dashboards to create a new dashboard app.
Populate the date field values in a new field
  1. Log in to the ArcGIS Online organizational account.
  2. Click Content, and click the My Content tab. Select the hosted feature layer to open the item details page.
  3. On the layer’s item page, click the Data tab.
  4. Add a new string field in the Table or Fields view. Refer to ArcGIS Online: Add or delete a field for steps to do so.
Adding a new string field in the Add Field window.
  1. Click the column of the newly created field, and select Calculate.
  2. In the Calculate Field window, select SQL.
  3. Select Date under Fields, and click the original date field. Click Calculate.
Populate the date field values in a new field using the Calculate function.
  1. Open the layer in ArcGIS Online Map Viewer, and set the new field for labeling. Refer to ArcGIS Online: Configure labels (Map Viewer) for steps to do so.
  2. On the Contents toolbar on the left side, click More > Create app.
  3. Select Dashboards to create a new dashboard in ArcGIS Dashboards.
Article ID: 000026069
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
