PROBLEM
Inconsistent spacing between headings in ArcGIS StoryMaps navigation bars
First Published: December 30, 2025
Last Published: December 30, 2025
In ArcGIS StoryMaps, inconsistent spacing is displayed between headings on the navigation bar, which creates a distracting visual gap and affects the overall navigation flow. The image below illustrates this issue, showing a wider gap between the second and the third headings.
The navigation bar with inconsistent spacing between headings in ArcGIS StoryMaps
Cause
An empty heading text block exists between the inconsistently spaced headings. This block is often overlooked because its outline is only visible when selected during editing and is not displayed as an empty space in immersive blocks after publishing. The empty heading text block remains in the story even when empty, and ArcGIS StoryMaps detects the block as a heading, causing inconsistent spacing in the navigation bar.
Solution or Workaround
Uncheck the empty heading check box in the Story navigation properties panel
  1. Open the story on the story map’s edit page.
  2. Uncheck the empty heading check box.
    1. Hover over the navigation bar and click Options The Options icon.
    2. In the Story navigation properties panel, uncheck the check box of the empty heading.
The 'Story navigation' properties panel
    1. Click Save.
The inconsistent spacing between the second and the third headings is removed.
The navigation bar in ArcGIS StoryMaps
Delete the empty heading text block from the story
  2. Delete the empty heading text block.
    1. Scroll to the section with the inconsistent spacing.
    2. On the desired section, click the empty heading text block. In this example, the empty heading text block is in the narrative panel of a sidecar block.
The empty heading text block in the narrative panel of a sidecar block
    1. Press Delete to remove the block.
Article ID: 000039413
Software:
  • ArcGIS StoryMaps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
