PROBLEM
"Data Error" message returned when accessing the Data tab in ArcGIS Online
Last Published: October 18, 2024
In ArcGIS Online, the Data tab of a hosted feature layer provides easy access to the layer's tabular data for editing, simple analysis, and field calculations via the item details page. However, when viewing the Data tab of the hosted feature layer associated with a published ArcGIS Survey123 Connect survey, the attribute table may return the following error:
Error:
Data Error
The Data tab of a hosted feature layer in ArcGIS Online.
Cause
The field names of the survey form contain reserved keywords or special characters.
Solution or Workaround
In ArcGIS Survey123 Connect, remove the reserved keywords or special characters, and rename them. After editing the field names, republish the survey form. Refer to ArcGIS Survey123: Update a survey for more information.
Article ID: 000033645
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Survey123 Connect
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
