PROBLEM
Arctoolbox dialog boxes do not show up on screen
The Arctoolbox dialog boxes do not display on the screen, however, they do appear to show up on the taskbar.
The content in this article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cause
The window position in the Registry has incorrect or negative values.
Solution or Workaround
Before following any of the procedures below, connect a second monitor and reconfigure the Display Settings in Windows by extending the main display. If the dialog box is visible in the extended display area, drag it to the primary monitor. Close and restart ArcMap.
If the dialog box is still not visible, try adjusting screen resolution. If the dialog box is visible, drag it to the primary monitor. Close and restart ArcMap.
Change the window position of the dialog box in the Registry.
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
  1. Navigate to Start > Run, type regedit and click OK.
  2. Navigate to HKEY_CURRENT_USER\Software\ESRI\ArcToolbox\Settings.
  3. Double-click the DlgWindowPos and change the data value to 1,1,1,1.
  4. Click OK.
  5. Close the Registry Editor.
  6. Start ArcMap. Try to use some of the Arctoolbox tools; the dialog box should now be on the screen.
In some 10.x versions of ArcGIS Desktop, a problem has been identified where the new Registry settings are not maintained. This has been logged as BUG-000115257 .
If this is the case, the following workaround is offered, however with some caveats.
Warning:
The following workaround may have unintended results. Renaming the Normal.mxt template may remove any ArcMap customization, such as activated toolbars, toolbar/panel positioning, and folder/database connections.
  1. In a file browser such as Windows Explorer, navigate to the Templates folder. The path is specific to the version in use, but follows the same general pattern as shown below:
    • C:\Users\<username>\AppData\Roaming\Esri\Desktop10.6\ArcMap\Templates
  2. Rename Normal.mxt (for example, Normal.mxt.old).
  3. Close and reopen ArcMap.
For more information about the Normal.mxt file, read the following web help document, Fundamentals of saving your customizations.
Article ID:000008829
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
