PROBLEM
In ArcGIS Pro, the Erase tool runs successfully with an empty output generated and returns the following warning, "Warning 000117: Warning empty output generated."
The parameters are configured with identical inputs or the polygons overlap each other perfectly. When the input feature and erase feature have the same feature layer, the tool erases everything within the features and returns an empty feature. The situation is similar when the input and erase feature are different but overlap each other completely, erasing everything within the feature.
The borders of the polygon can be edited to not completely overlap each other. Refer to ArcGIS Pro: Reshape feature geometry to edit a polygon border. Alternatively, another overlapping polygon can be selected to replace one of the parameters for the Erase tool.
Ensure the feature layers for the Input Features and Erase Features parameters are different.
Article ID: 000031297
Get help from ArcGIS experts
Start chatting now
