ERROR
Map graphics exceed maximum size limit of 10 MB. One or more layers cannot be added.
Last Published: August 14, 2024
Error Message
In ArcGIS Pro, when adding a graphic layer from the Add Graphics Layer tool, or adding a layer package, an error message is returned:
Error:
add data error
Cause
Graphic layers are not stored in a geodatabase, hence it is very inefficient to read and render them. ArcMap users have experienced slow performing map files (.mxds) only to find they had thousands of graphics instead of actual features in feature classes, shapefiles, etc. Instituting the limit in ArcGIS Pro (10 MB) is a compromise to allow the use of graphics but keep maps relatively performant.
In these situations, the best option is to save the data as feature classes. Convert the graphic layers into feature classes using the Graphics To Features tool in ArcGIS Pro: Graphics To Features (Conversion)
Solution or Workaround
  1. In ArcGIS Pro, open the geoprocessing pane and search for and open the Graphics To Features tool.
  2. For Input Graphics, choose from the drop-down list the graphic to convert to a feature class.
designating the name and location of the input graphics
  1. For Graphics Type, specify the type of graphic element to convert.
selecting the graphics type
  1. In Output Feature Class, select the destination geodatabase and name of the new feature class.
providing a name and output location for the feature class
  1. Run the tool.
Article ID: 000032772
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
