HOW TO
Instructions provided outline steps for importing an MapInfo interchange file (.MIF) using ArcGIS 9.x.
Note: This article applies to retired ArcGIS versions 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools. For instructions for ArcGIS Pro, see: Import a MapInfo Interchange Format file into ArcGIS Pro
![[O-Image] Conversion Tools drop down](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000006904/00N39000003LL2C-0EM39000000wcol.png)
![[O-Image] MIF to Shapefile dialog](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000006904/00N39000003LL2C-0EM39000000wcok.png)
Note: Folder names in the path to the input and output datasets are limited to 8 characters. If input or output data are located in a path with folder names longer than 8 characters, the tool fails with the message: "Error! Unable to finish conversion." The same error message will be returned if more than 32763 nodes per REGION or LINE and 3000 polygons per REGION exist in the input data.
Article ID: 000006904
Get help from ArcGIS experts
Start chatting now
