HOW TO
A MapInfo Interchange Format (MIF) file is a map file and database exporting file format containing boundary objects, (for example, areas, curves, and points) and associated information such as color, thickness, and style. However, MIF files are not supported in ArcGIS Pro, but the files can be imported into ArcGIS Pro as geodatabase files. This article describes the workflow to import a MIF file into ArcGIS Pro.
Note: The Quick Import tool requires the ArcGIS Data Interoperability extension and the Data Interoperability license. Refer to ArcGIS Pro: Installing the ArcGIS Data Interoperability extension to install the ArcGIS Data Interoperability extension in ArcGIS Pro, and ArcGIS Pro: Authorize extension licenses to assign the extension license.
.Note: Optionally, click More Formats…, search for and select Precisely MapInfo MIF/MID from the format list in the FME Reader Gallery dialog box, and click OK.
, and select the MIF file from the Select 'File' dialog box.Note: To select multiple files or folders, or files from the web, click the Open file browsermenu, and select Select Multiple Folders/Files… or Select File From Web.
to specify the location of the file geodatabase.
The image below shows the file geodatabase imported from the MIF file into ArcGIS Pro.
Article ID: 000029745
Get help from ArcGIS experts
Start chatting now
