HOW TO
In ArcGIS Pro, feature boundaries are commonly symbolized using a single stroke layer defined by different colors, widths, and styles. However, in certain scenarios, combining graphical elements and attribute values with the stroke layer enhances boundary representation and can be achieved by adding multiple marker symbol layers into the existing symbology. For example, in town planning, triangular symbols and lot number markers can be incorporated to represent the parcel boundaries according to project needs or cartographic conventions.
Complete the workflow provided to symbolize polygon boundaries by adding graphical elements and attribute markers to the existing symbology. The image below shows the Account Numbers field to be used as the attribute markers.
The marker layer is added to the symbol.
The map below shows the triangular markers added to the existing boundaries' symbology.
The duplicated marker layer is added to the symbol.
"<name>" + " = " + $feature.<field>
Note: Alternatively, in the Set Attribute Mapping dialog box, select the desired field from the drop-down list to be symbolized at the boundaries.![]()
The map below shows the attribute markers added to the existing boundaries' symbology.
Note: When duplicating a marker symbol layer, the new layer inherits the configurations and placement properties of the original layer. If necessary, modify the placement settings to prevent overlapping. Refer to ArcGIS Pro: Modify symbols for more information.
The map below shows the triangular symbols and attribute markers with their placement configured in ArcGIS Pro.
Article ID: 000035244
Get help from ArcGIS experts
Start chatting now
