HOW TO
Place picture markers on line features in ArcGIS Pro
Last Published: August 29, 2023
Summary
In some instances, picture markers are placed on line features as a label, symbology, feature, representation, or decoration in ArcGIS Pro. This is done by creating a new picture marker symbol layer for the line layer or creating point features along the line features. This article provides the instructions to place picture markers on line features in ArcGIS Pro.
Procedure
Follow one of the steps below for the desired outcome.
Add a new symbol layer to the line feature symbology
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the line feature layer, and select Symbology.
  3. In the Symbology pane, on the Primary symbology tab, click the line symbol.
The line symbol in the Symbology pane.
  1. Add a new marker symbol layer.
    1. In the Format Line Symbol pane, on the Properties tab, click the Structure tab.
    2. Expand Layers, click Add symbol layer, and select Marker layer from the drop-down list. The new marker symbol layer is added.
    3. Optionally, click the delete button The Delete icon. on the existing stroke symbol layer to delete it.
The symbology properties in the Format Line Symbol pane.
  1. Configure the marker symbol layer.
    1. In the Format Line Symbol pane, on the Properties tab, on the Layers tab, select Picture marker from the drop-down list.
    2. Expand Appearance. Under Insert picture from, click File... to select the image. If necessary, adjust the Position, Rotation, Offset Distance, and Marker Placement.
    3. Click Apply.
The marker symbol properties in the Format Line Symbol pane.
The image below shows animal footprints to trace the steps of an animal in the map by importing the image on the line feature.
The imported image of animal footprints as the line feature.
Create point features along the line features
  2. Create point features along the line features. Refer to ArcGIS Pro: Create points along multiple lines in ArcGIS Pro for further instructions.
  3. In the Contents pane, right-click the newly created point feature layer, and select Symbology.
  4. In the Symbology pane, on the Primary symbology tab, click the point symbol.
The point symbol in the Symbology pane.
    2. Expand Appearance. Under Insert picture from, click File... to select the image. If necessary, adjust the Position, Rotation, and Offset Distance.
    3. Click Apply.
The image below shows an example of an imported image used to represent the direction of an airplane after creating point features along the line features.
Airplanes as symbology on the line feature.
Article ID: 000031022
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
