HOW TO
Renumber the map grid index for a spatial map series in ArcGIS Pro
First Published: October 4, 2023
Last Published: March 30, 2026
Summary
A map grid is a rectangular polygon feature used as an index to specify pages in a spatial map series. At times, it is necessary to renumber the grid index after removing grids from a map, as it causes the index to be non-consequential. Renumbering the map grid index ensures the data is organized and updated for use. This article provides the workflow to renumber the map grid index after deleting grids in ArcGIS Pro.
The attribute table below shows the map grid index number 3 is missing in the PageNumber field when a grid is deleted.
The PageNumber field with a missing page number
Procedure
  1. Open the ArcGIS Pro project with the map grid layer in ArcGIS Pro.
  2. In the Contents pane, right-click the layer and click Attribute Table to open the layer's attribute table.
The Attribute Table option
  1. Right-click the map grid index field in the attribute table and click Calculate Field. In this example, the 'PageNumber' field is selected.
The Calculate Field option
  1. In the Calculate Field window, configure the parameters.
    1. For Input Table, ensure the preferred layer is prefilled. In this example, the input table is 'countyBoundaries_SpatialJoin'.
    2. For Field Name (Existing or New), ensure the selected field name is prefilled. Otherwise, select the field from the drop-down menu. In this example, the field name is 'PageNumber'.
    3. For Expression Type, select Python.
    4. For Expression, type the first code for the <field name> = expression box, and the second code under Code Block.
autoIncrement(1, 1)
rec = 0
def autoIncrement(start=1, interval=1):
    global rec
    if rec == 0:
       rec = start
    else:
       rec += interval
       return rec
  1. Click OK.
The Calculate Field window and the parameters
The Calculate Field tool permanently modifies inputs by changing values in the attribute fields. To avoid having permanent changes applied, toggle Enable Undo on in the Calculate Field window before running the tool.
The attribute table below shows the map grid index field is consequentially renumbered.
The consequential page number in the field after the calculation
Article ID: 000031245
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
