HOW TO
Prevent details in the Feature Info widget from displaying when launching an experience in ArcGIS Experience Builder
First Published: January 5, 2023
Last Published: August 26, 2026
Summary
In ArcGIS Experience Builder, the Feature Info widget displays details about data from a feature layer or scene layer. By default, the widget selects and displays the first record in the list when the data source view is set to 'Default'. In some instances, it may not be ideal to display any records and to keep the widget blank when the experience is launched.
This article describes the workflow to prevent details from displaying by default in the Feature Info widget when launching an experience in ArcGIS Experience Builder.
Procedure
This workaround requires the usage of certain widgets to be alongside the Feature Info widget. In this example, the Map widget is used.
  1. Open the ArcGIS Experience Builder project and navigate to the Insert widget panel.
  2. Under Map centric, drag and drop the Map widget to a desired position on the experience.
  3. In the Map widget’s configuration pane, under Source, click Select map.
  4. In the Select data pane, select a web map. If needed, click Add new data to add a new web map from ArcGIS Online.
  5. Navigate to the Insert widget panel, under Data centric, drag and drop the Feature Info widget to a desired position on the experience.
  6. In the Feature Info widget's configuration pane, under Source, click Select data.
  7. Under Source, select a feature layer. If needed, click Add data to add a new feature layer from ArcGIS Online.
  8. In the Content configuration pane, under Data, navigate to the added data.
  9. In the data source views drop-down list, select Selected features.
Select the Selected features data view
  1. Optionally, in the Feature Info pane, under General, specify a message to be displayed in the Feature Info widget when no features are selected in the Map widget as shown in the image below.
Specify a no data message
  1. Click Save The Save button to save the experience.
The image below demonstrates details in the Feature Info widget are not displayed when the experience is launched and only displays the details when a feature is selected in the Map widget.
The Feature Info widget only displays records once a feature is selected in the Map widget
Article ID: 000029047
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
