HOW TO
Issues related to application profile failure and applications crashing can occur in ArcGIS Desktop if the registry entry is corrupted. Performing a soft reset resolves the issue by closing applications and clearing data in the RAM, in contrast to a hard reset, where user data are removed, and the device is restored to its factory settings.
This article describes how to perform a soft ArcGIS Desktop reset.
Note: ArcMap has been retired as of March 1, 2026. There are no plans for future releases of ArcMap, and migration to ArcGIS Pro is recommended. Refer to ArcGIS Desktop is retired for more information.
Perform a soft reset by renaming the roaming and local profiles, and editing the Windows registry for ArcGIS Desktop applications.
Note: If there are concurrent licenses on the machine, return the borrowed licenses before performing the workarounds below. For more information on borrowed licenses, refer to ArcMap: Borrowing and returning concurrent use licenses.
Rename the roaming and local profiles
Note: The AppData folder is hidden. To display hidden folders, refer to Microsoft Windows Support: Show hidden files.
C:\Users\YourUsername\AppData
C:\Users\YourUsername\AppData\Roaming\ESRI\Desktop10.7
C:\Users\YourUsername\AppData\Local\ESRI\Desktop10.7
Make edits in the Registry Editor
Warning: Editing the Windows registry requires administrator privileges on the machine and must only be done as a last resort. Perform a backup of the registry or machine before proceeding with the steps below. Consult a qualified computer systems professional, if necessary. Esri is not liable for incorrect modifications following these instructions. User discretion is advised.
A new Desktop10.7 folder is created when the ArcGIS Desktop application is launched.
Article ID: 000014992
Get help from ArcGIS experts
Start chatting now
