HOW TO
Perform a clean uninstall and reinstall of ArcGIS Pro
First Published: July 25, 2023
Last Published: July 15, 2026
Summary
This article walks through the process of removing remnant files that might be left over from a corrupt install or incomplete uninstall of ArcGIS Pro.
Corrupt installs of ArcGIS Pro may cause an incomplete software uninstall from the system when using the Windows Control Panel, and may also cause issues with operating the software or installing the software after uninstalling it previously.
Before proceeding with a clean uninstall and reinstall, problems with the Windows profile should first be ruled out by having another user log into the computer and see if the problem is reproducible under another user’s login.  If the problem CANNOT be reproduced by another user on the same machine, a clean uninstall is unlikely to help, and the Windows user profile should be reset or replaced instead.  This is a system issue and IT staff should be able to accomplish this task.  If the customer doesn’t have IT staff available, there are instructions for this process on the Microsoft website. If another user CAN reproduce the problem, this indicates a problem with the software and a clean uninstall can be pursued.
Procedure
  1. Close the ArcGIS Pro application if it is open.
  2. Run the uninstall for your Esri product via Control Panel > Programs > Programs and Features. Select your ArcGIS Pro product, right-click the item, select Uninstall/Change and follow the prompts choosing to remove the software.  Uninstall ArcGIS Pro and any related extensions such as Data Interoperability.
  3. Ensure that all ArcGIS Pro processes are not running in the Task Manager. These are usually the following:
    • ArcGISCleanup.exe
    • ArcGISPro.exe
  4. Rename the following folders, if they still exist, by appending "_OLD" to the end of the folder name:
    • C:\Users\<username>\AppData\Local\ESRI\ArcGISPro and any other Pro folders
• Rename the ArcGISPro folders to ArcGISPro_old rather than deleting the folders to preserve a backup.
• The AppData folder is hidden by default. For more information, refer to: Microsoft Support: Show hidden files
    • C:\Users\<username>\AppData\Roaming\ESRI\ArcGISPro
Favorites are also stored in the ...\AppData\Roaming\... directory.  Deleting or renaming this folder will cause Favorites to be reset.  For more information, refer to: Use project favorites
    • C:\Program Files\ArcGIS\Pro
    • C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcGIS\ArcGIS Pro
  1. Manually delete the following folder:
    • C:\Users\Documents\ArcGIS\Addins
  2. Reboot the system, and run the install of ArcGIS Pro. This should allow installing the software as new.
Article ID: 000030419
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
