HOW TO
ArcGIS Field Maps can run on a Windows 11 machine using a new virtualization capability called Windows Subsystem for Android (WSA). WSA allows a Windows 11 device to run Android applications that are available in the Amazon Appstore.
Note: • The Amazon Appstore is not available in every country (list of supported countries). • Apps available in the Amazon Appstore, including Field Maps, do not have dependencies on Google Play Services. • Some computer settings may prevent install, and you may need to consult with your IT department.
The ArcGIS Field Maps mobile app was added to the Amazon Appstore to support ArcGIS Field Maps customers using Windows 11. This article describes how to install the ArcGIS Field Maps mobile app on a Windows 11 device.
System requirements:
System requirements are also listed on the Microsoft support site: Install mobile apps and the Amazon Appstore on Windows.
User requirements:
Note: If Install is disabled, ensure you have Virtual Machine Platform enabled. See step 3 of Enable virtualization on Windows 11 PCs to learn how to enable this setting.
After Amazon Appstore is installed, a prompt appears.
ArcGIS Field Maps mobile app appears in the search results, as shown in the following image.
After the app is installed, ArcGIS Field Maps is added to the Start menu.
The ArcGIS Field Maps splash page appears, as shown below, where you can sign into your ArcGIS account and begin using the app.
Article ID:000030715
Get help from ArcGIS experts
Download the Esri Support App
